1996 Honda Accord Drivablity
112,000 MILES • 4 CYL • 2WD • MANUAL
RSNYDER007
Vehicle is surging, and has no acceleration. Once at speed, surging stops. Check engine lamp came on.
codes: P301 - cyl 1 misfire
P302 - cyl 2 misfire
p1300 - ignition timing adjustment circuit failure
Could this possibly be a clogged catalytic converter. Vehicle has had the plugs, cap and rotor replaced.
Dec 3, 2007 at 11:16 AM
  • 31,937 POSTS
Hi there,
It may be a faulty fuel injector, or an ignition electrical problem, If you have the engine run on an oscilloscope, it will show ignition patterns voltages, Resistances . this will help diagnose any electrical fault. try this first.
Mark (mhpautos)
Dec 3, 2007 at 12:27 PM
