This Honda was overheating really bad and spraying coolant out of the water pump. We replaced the water pump and then decided to run water thru the system to test it out and it was leaking really bad with no pressure. Everything was tight. It mainly leaked on the driver's side near the water pump and the connecting pipe. It also leaked a little on the passenger side where the connecting pipe connects to the thermostat housing. We removed the connecting pipe and it looked good, and the o-rings looked fine. I have no idea why it is leaking with no pressure at all. The car was run for a while when it was overheating and I fear it might have cracked the head... What do you think?
Thanks,
Sam
Thanks,
Sam
Apr 20, 2010 at 3:31 PM
