1996 Honda Accord clutch troubles
203,000 MILES • 4 CYL • FWD • MANUAL
C80BOMJXP
well, i'm having sum troubles with my clutch, sometimes it's not engaging all the way, i just bought the car don't know much about it's history, when the car is cold, the clutch works fine but when up to temp for a while (or when ever i feels like it) it's not engaging all the way, i can feel it in the pedal it feels spungy, i just bled the clutch, and changed the tranny fluid, that worked for about 2 days. Then the problem came back. hope to hear from you soon. thx for the help...
Feb 3, 2010 at 1:54 PM
KHLOW2008
  • 41,812 POSTS
Hi c80bomjxp,
With engine started, depress the clutch and engage 1st gear. Hold the clutch and if the vehicle tends to move forward after a short while, it indicartes a fault with the hydraulic system, it is leaking internally causing the pressure to drop.
Do you have any issues with the clutch fluid depleting?
Feb 6, 2010 at 2:12 PM
