1996 Honda Accord Clutch master & slave cylinders
116,000 MILES • 4 CYL • FWD • MANUAL
DOCFLETCHER
Both the clutch master and slave cylinders are seeping fluid externally.
Are the repair kits worth doing with these cylinders?
Or do you believe the cylinders should be replaced rather than repaired?
Thanks for your help.
Apr 16, 2009 at 4:52 AM
F4I_GUY
  • 3,302 POSTS
Personally the slave cylinder, I would just replace. The price for a rebuilt or new one is very cheap.
The master cylinder is a toss up. What price can you get a rebuilt one for? How about the rebuilt kit?
In my opinion, I would purchase new or rebuild parts for both, you may have done damaged to the housing bores, that you may not be able to rebuild with that kit.
Apr 16, 2009 at 12:37 PM
DOCFLETCHER
Cylinders from Honda $300. Rock auto has a pretty good selection, from $30 to $58 for each cylinder.
Repair kits about $28 for both.
I think I'll try the repair kits. Should be able to hone out the bore.
Apr 16, 2009 at 1:28 PM
F4I_GUY
  • 3,302 POSTS
Okay, goodluck.
Apr 17, 2009 at 10:55 AM
