1996 Honda Accord Catalytic Converter Deficiency
240,000 MILES • 4 CYL • FWD • AUTOMATIC
REDDISHS
  • 5 POSTS
When my check engine light came on I had it checked and the error message was Catalytic Converter Deficiency. I had the catalytic replaced by a local shop that welded on a new catalytic instead of using a after market factory bolt on like Honda uses. A week later the check engine light came on again with the same error message "Catalytic Converter Deficiency". Another shop told me that because the other shop didn't use the proper catalytic for my Honda that I will continue to get a check engine light until I replace the catalytic again with the correct catalytic. Is this correct??
Aug 20, 2008 at 12:50 AM
2CARPRO JACK
  • 11,533 POSTS
Yes, if they used the wrong one the PCM wont see the efficiency as being within parameters and will trigger the light
Aug 20, 2008 at 12:58 AM
REDDISHS
  • 5 POSTS
2CarPro Jack,
How do I find the right catalytic converter for my car and replace it myself? Also, what is the sensor that is just before the catalytic converter?
Thanks
reddishs
Aug 20, 2008 at 4:52 AM
2CARPRO JACK
  • 11,533 POSTS
The dealer wouldl be the best bet for the correct one, but if he welded in an aftermarket, you may not be able to replace it yourself, since it is no longer a bolt in installation. The sensor before the cat is the upstream oxygen sensor.
Aug 20, 2008 at 5:19 AM
