1996 Honda Accord bogging at acceleration
114,144 MILES • 4 CYL • 2WD • AUTOMATIC
STEPHENROD
the car bogs at acceleration then accelrates fine after a certain point changed wire checked fuel pressure 35 dead pressure 40-45 running the CEl is not on
Aug 15, 2010 at 8:25 AM
  • 75,988 POSTS
If you pinch of the fuel return line the dead head pressure should increase 2X over the normal pressure which is 30-37psi and your running pressure at this time is 40-45psi your lil bit on the high side.
If you remove the vac hose on the regulator is should increase between 8-10 psi over, vac hose connected 30-37 psi
Other areas will caused it to bogged/hesistate:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Aug 15, 2010 at 11:13 AM
STEPHENROD
the car is still stumbling and backfiring through the intake while in park and slight acceleration. i have checked everything on you list even cleaned the EGR ports. could it be the distibutor?
Aug 16, 2010 at 5:00 AM
  • 75,988 POSTS
Could be intake valves sticking
Aug 16, 2010 at 10:21 AM
