Normally the antilock system brake light when car starts lights for a short time and turns off. This, I know is normal. Recently, after about a minute or so with the light off, even when the car is parked and running, the light turns on again and stays on. I noticed that I heard one single click sounding when the light first popped on and stayed on. After some searching, I located the single click coming from the ABS Pump Motor Relay located in the ABS "black box" along side with several fuses. I am 100% sure the click is coming from the relay when the light pops on.
Two questions: 1) Could the click indicate that the ABS pump motor relay is dead and needs replacing... perhaps this is why the light comes on? Or, is the relay doing something that it is intended to do if another part is failing? Sorry... my ignorance about what a relay is meant to do. Should I replace the relay?
2) Can we use the car if the ABS light is on, until I find the cause? The brakes are still working normally... correct?
Thanks for any info you can give.
Dec 17, 2008 at 4:52 PM
