1995 Honda Accord Turn Signals
120,000 MILES • 4 CYL • FWD • AUTOMATIC
SKADOM21
After replacing the battery, the turn signals have stopped working. They light up ( all the bulbs work), however when you signal to turn the lights don't flash. The indicator on the instrument cluster lights up but stays lit, there is no "flashing". I have checked the fuses and they are not shorted. Is this a grounding problem or a short somewhere else in the system??
The chilton guide was of no use either! No topics on how to correct this problem.
Dec 19, 2008 at 7:02 AM
KHLOW2008
  • 41,812 POSTS
Hi skadom21,
Does the hazard lights functioning normally?
It should be a problem with the flasher relay or its wiring and not external.
Dec 24, 2008 at 2:37 PM
