After replacing the battery, the turn signals have stopped working. They light up ( all the bulbs work), however when you signal to turn the lights don't flash. The indicator on the instrument cluster lights up but stays lit, there is no "flashing". I have checked the fuses and they are not shorted. Is this a grounding problem or a short somewhere else in the system??
The chilton guide was of no use either! No topics on how to correct this problem.
Dec 19, 2008 at 7:02 AM
