Transmission problem
1995 Honda Accord 4 cyl Front Wheel Drive Automatic 320K miles
I have a noise when engine braking in 4th gear, if you let the vehicle engine brake between 110k and 80k, I get an almost metal on metal sound. By downshifting a gear or depressing the accelerator, the noise disappears. It does this everytime without fail. Recently the seal between motor and trans was replaced, the dealer forgot to put in a retaining clip on the driveline and lost all fluids. This was remedied but I have wound up with this existing fault. Any suggestions?
Nov 5, 2010 at 8:45 AM
