1995 Honda Accord transmission leaks fluid
1995 HONDA ACCORD
200,000 MILES • 4 CYL • FWD • AUTOMATIC
541DOORGUY
i just bought a used 95 honda accord a couple weeks ago. today i got under it to change the oil and found transmission fluid all over the bottom of the transmission. it was around were the big gasket is, but did'nt apear to be the gasket that was leaking. i could'nt tell if it was coming from the transaxle seal or the speedometer input. it was all over as if it was leaking from the casing itself, but there were no cracks. is there a common problem with these tranys leaking from somewere specific?
Mar 20, 2009 at 2:48 AM
