1995 Honda Accord Transmission? Clutch??
186,000 MILES • 4 CYL • 2WD • MANUAL
JASONMASTR
Recent services: Clutch about a year ago from Clutch Doctors and CV boot replaced a month ago. Oil changed today.
When driving the car, while decelerating in gear, the car makes a chirping noise that varies in noise level. 2nd and 3rd gear mostly. . . when I put the clutch in it stops after a second and if it's in neutral it's does not make the sound.
Clutch? Transmisstion? Not sure where to start.
Thank you for your help.
Jason
Oct 13, 2009 at 7:05 PM
F4I_GUY
  • 3,302 POSTS
Sounds like a bearing to me. It may be hard to pin-point which bearing it is though. Sounds like an input shaft bearing to me. Either way, the transmission is going to have to be dropped.
Oct 15, 2009 at 12:11 PM
