1995 Honda Accord Transmision leaking
165,000 MILES • 4 CYL • FWD • AUTOMATIC
NIGHTDIAMOND
I have a problem with my 95 honda accord it started with me turning and most of the time when I do turn and push the gas it doesnt kick in intell a few second later.A few months later now the transmission leak the fluid as quickly as i put in when i turn on the car it make a snake sound and then it start to pour out.
Sep 29, 2009 at 8:47 AM
KHLOW2008
  • 41,812 POSTS
Hi nightdiamond,
You have a bad leak somewhere and it could be the pressure line to or from the radiator, torque converter oil seal or any of the pressure testing bolts. You would need a visual inspection to locate the leak.
When fluid level is low, it would cause shifting irregularities.
Sep 30, 2009 at 7:34 AM
