How do I replace the brake rotors
316,000 MILES • 6 CYL • FWD • AUTOMATIC
MANNYM925
How do I replace the brake rotors on this accord model and do you have a step by step ilustraded?
Aug 9, 2010 at 4:27 AM
KHLOW2008
  • 41,812 POSTS
Hi mannym925, The wheel bearing and knuckle assy has to be removed when replacing the front rotors. HUB & KNUCKLE ASSEMBLY Removal 1.Loosen lug nuts with vehicle weight on tires. Pry lock tab away from spindle nut, and loosen nut. Raise and support vehicle. Remove lug nuts and spindle nut. Remove wheel assembly. Remove caliper assembly, and support aside. DO NOT put weight on flexible brake line. 2.Remove cotter pin and nut from tie rod end. Using Ball Joint Remover (07MAC-SL00200), separate tie rod ball joint and lift tie rod end out of knuckle. Remove cotter pin from lower control arm ball joint, and loosen castle nut half length of joint threads. See Fig. 2 . Using ball joint separator, separate lower ball joint from control arm. Remove nut. 3.Remove hub/knuckle from control arm. Remove cotter pin and nut from upper ball joint. Using ball joint remover, separate ball joint from upper control arm. Slide axle shaft from knuckle and hub assembly. Support axle shaft with wire. Remove hub/knuckle assembly. Installation To install hub/knuckle, reverse removal procedure. Tighten bolts and nuts to specification. Use NEW spindle nut, and stake after tightening.
https://images.2carpros.com/forum/automotive_pictures/192750_FRTKnuckle98AccordFig02_2.jpg
WHEEL BEARINGS Removal Remove steering knuckle. Remove splash guard (if necessary). Remove steering knuckle-to-hub mounting bolts and separate hub from steering knuckle. Clean knuckle and hub thoroughly before reassembly. Installation Install splash guard (if removed). Bolt hub to steering knuckle. Tighten bolts to specification. To complete installation, reverse removal procedure.
Apr 9, 2021 at 4:07 AM
