1995 Honda Accord Radiater fan
220,000 MILES • 4 CYL • 2WD • AUTOMATIC
BERGY1956
The radiater fan does not turn on at all.
Dec 2, 2008 at 6:57 AM
F4I_GUY
  • 3,302 POSTS
Remove the fan switch located on the thermostat housing (its a 2 pin harness clip) Jump it with a wire. Does the fan turn on?
Have you checked fuses? You can also run fused power to the fan motor itself to see if the fan itself is still functioning. Usually you'll find its a relay or switch acting up though
Dec 2, 2008 at 9:12 AM
