Remove the fan switch located on the thermostat housing (its a 2 pin harness clip) Jump it with a wire. Does the fan turn on?
Have you checked fuses? You can also run fused power to the fan motor itself to see if the fan itself is still functioning. Usually you'll find its a relay or switch acting up though
SPONSORED LINKS
Tuesday, December 2nd, 2008 AT 5:12 PM
