1995 Honda Accord Oil Light
LACY0923
Engine Mechanical problem
1995 Honda Accord 4 cyl Two Wheel Drive Automatic 195K miles
My oil light has started to come on indicating low oil pressure. I have checked and the oil level is sufficient (it does leak a little). When the oil light comes on, I can turn the motor off and immedietly restart. The oil light will go off. It may not come on again for several days. I can then follow the same sequence and I am off and running again.
What could cause this? Is the oil pump screen clogged? dirty filter?
Feb 27, 2008 at 6:24 AM
  • 75,988 POSTS
For a start get the oil pressure check -if normal replace the oil pressure sending unit. Not normal could mean a sloppy oil pump/engine bearings/sludge problem-pick-up screen/filter/oil galleries.
Feb 27, 2008 at 8:03 AM
