1995 Honda Accord Not switching gears
KUMEN209
  • 1995 HONDA ACCORD
  • 4 CYL
  • 24,000 MILES
Im having problems with my transmission with gears not wanting to grip or shift. Started having this problem a couple months ago, just haven't had the time or the money to fix it. Hoping its not that big of a problem and it's something I can work on at home. As soon as I start off, it takes a bit to get in gear (reverse has no problems). As its going through gear 1 to gear 2 it seems to go to a higher rpm than usual before it shifts to 2nd gear. But here is where my bigger problem lies, sometimes it shifts from 2nd to 3rd and sometimes it doesnt. It doesnt shift into 4th gear at all. Now my engine light is on as well. I just had my engine replaced about a year ago, but I rarely used my car because I had my '01 Civic to get around in. Since replacing my engine I've put in maybe 25,000 miles. A few buddies of mine said it might be the cylinoide, but I'd like to know exactly what it could be if possible.
Wednesday, August 12th, 2009 AT 10:12 AM
KHLOW2008
  • 41,814 POSTS
Hi kumen209,
You would need to retrieve the trouble code to know what is causing the MIL to indicate.
Here are the procedures.
Bridge the SCS connector, turn ignition switch to ON and count the blinking of the MIL.
Delayed flash = 10 counts.
Short quick flashes = 1.
Code would repeat once a cycle is complete.
Watch and count the D4 light if it blinks as well.
https://www.2carpros.com/forum/automotive_pictures/192750_SCS95Accord_2.jpg
As to transmission shifting incorrectly,
Did you check the trans fluid level?
Was the trans throttle pressure cable adjusted correctly?
Is the speedometer corking correctly?
Wednesday, August 19th, 2009 AT 4:08 AM
