1995 Honda Accord no heat revving in Park; fan stays on aft
SOSMUN
Heater problem
1995 Honda Accord 85,000 miles
My daughter's Honda Accord (sorry do not have engine size or some other information) this afternoon started revving quite loudly in Park. Kicking it down did help once but statrted revving again and remained revving until put into Drive. There was no heat and the fan remained on after she took the key out. Any ideas what might be going on?
Nov 17, 2008 at 9:10 AM
ZACKMAN
  • 4,202 POSTS
For high idle problem:
1. Check throttle cable for any possible damage
2. Clean throttle body from carbon build up
3. Remove, clean, and re-install idle air control motor
4. Check throttle position sensor operation
5. Check for loose, broken, pinched vacuum hoses and lines
No heat
Do you have enough coolant?
Check your coolant temp sensor
Fan
Your fan should stay on until the engine cools off. If it stays on for more than 10 minutes, check fan relay, under the hood. This can be related to no heat if your heater core is plugged up.
Nov 17, 2008 at 2:56 PM
