1995 Honda Accord my car shacks
15,555 MILES • V8 • FWD • AUTOMATIC
DAVILA969
i got into a car accident a couple months ago, the front drivers side wheel fell off. i got the upper ball bearing replaced, had a wheel alignment, my tires balenced and on top of that got new tires. when im on the freeway driveing to work my car begins to shake. i cant tell if its the tires or the engine or what? could it have something to do with the transmission.
Aug 19, 2009 at 10:56 AM
KHLOW2008
  • 41,812 POSTS
Hi davila969,
When vibrations occurs at high speed, it is either the tires were not balanced well or you have a bad CV shaft or inboard joints.
If the vibrations increases with acceleration and reduces when accelerator is released, I would go for the CV shaft ( bent ) or inboard joint, ( bad or lacks lubrication).
Aug 24, 2009 at 3:16 AM
