1995 Honda Accord leaks
200,000 MILES • 6 CYL • 2WD • MANUAL
TSIMON7275
all of the oil leaked out of the engine next to the timing belt pulley. my mechanic says its some gasket and now i have to replace the timing belt and water pump. They looked at it and now telling me they want have of the repair money down to take car apart and then if its something else then I will have to pay more. Is this right?
May 21, 2010 at 7:10 AM
  • 31,937 POSTS
Hi there,
have the crank shaft seal and the cam seal replaced, if the timing belt is oil soaked it should be replaced, if the water pump is not leaking coolant, it will not require replacing at this time.
mark (mhpautos)
May 21, 2010 at 11:03 PM
