1995 Honda Accord jerking
148,000 MILES • 4 CYL • 2WD • MANUAL
JIMMYLEE
i have a 95 honda accord 5 speed and recenly i just got a new clutch kit put in and now after driving for about two months its starting to jerk in every gear while driving.When i give it more gas thats when it jerks.
Apr 14, 2010 at 9:08 AM
  • 75,988 POSTS
Lack of acceleration,chugging,hesitating,bogging etc. could be caused by one of the following below.
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Apr 14, 2010 at 1:10 PM
