1995 Honda Accord intermittent power outage
165,000 MILES • 4 CYL • FWD • MANUAL
RIECHERS
Sometimes when either decelerating in gear or when changing gears (and the engine RPM's reduce) all power with shut off for a split second. Power comes back on immediately but it can't be good for the components. Doesn't seem to happen at night with the lights on or when the heater/ac fan is on. Becoming more and more frequent. About 10% of the time after this happens and the car is shut off, the clock resets and one time the radio station memory presets reset to the factory defaults.
May 2, 2008 at 3:19 PM
ROB2008
  • 258 POSTS
I would check the for a loose battery terminal . or ground wire .
May 2, 2008 at 3:34 PM
