1995 Honda Accord ignition coil and distributor
195,000 MILES • 6 CYL • 2WD • AUTOMATIC
RONNYGILMORE
I just changed my ignition coil and had to remove the distributor to do it. All went well. Do I need to do anything else? I read in a manual that on some models you have to run some type of process to reset the car.
Oct 21, 2009 at 3:46 AM
HONDA TECH 1818
  • 536 POSTS
You just need to check the ignition timing when the engine is running in normal operating temperture.
Oct 21, 2009 at 2:34 PM
