1995 Honda Accord humming/grinding noise at 60mph
BRANDYCULVER
  • 1995 HONDA ACCORD
  • 4 CYL
  • 144,000 MILES
I have replaced the front left bearing with local mechanic since its little shaking. When picked up the car at low speed every thing was good but as I reach the noise ( wheee, wheee.) From the front somthing griding or rubbing -every I touch 60+ I hear the noice. Took back to mechanic - he says the transmission noice and nothing to do with the bearing that he changed. I wach him change the bearing - he did the work professionally ( I understand the Auto mechanics little). Any suggestion will be great help
Thanks
Brandy
Tuesday, May 25th, 2010 AT 11:57 AM
KHLOW2008
  • 41,814 POSTS
Hi Brandy,
When the speed is reached and the noise appears, shift to Neutral and if the noise goes away, then it is transmission related. If the noise is still present, then it should be road wheel or bearing related.
Friday, May 28th, 2010 AT 12:43 PM
