1995 Honda Accord fuel pump system
200,000 MILES • 4 CYL • FWD • AUTOMATIC
ILLUSIONMASTER804
replaced fuel pump relay and the fuel pump worked for about a week then quit again. the check eng light is on and d4 is lit up on the gear select even though the car is in park. It keeps shorting out the relays what could cause it?
Apr 10, 2009 at 5:00 AM
KHLOW2008
  • 41,812 POSTS
Hi illusionmaster804,
If no codes can be retrieved, the ECM is faulty.
If the PGM-FI main relay is used, resolder the circuit board and retry.
Apr 15, 2009 at 5:27 AM
