1995 Honda Accord Engine loud revving, overheating when dri
1995 HONDA ACCORD
110,000 MILES • 4 CYL • 2WD • AUTOMATIC
NAHAKU
Recent plugs, ign wire, rotor changed. Not air filter.
Car engine revs high, like racing when going normal speeds. Runs normal except when accelerating. But the higher speed you go (freeway) the engine races even higher and won't adjust like auto downshift, revs stay high through all gears, causing overheating too.
Dec 17, 2009 at 7:15 AM
  • 110,244 POSTS
Make sure the trans fluid is full. Also, can you tell if the transmission is shifting? If it is and the RPM's are going up, it sounds like the clutch plates are bad in the transmission.
Let me know what you find and thanks for using 2carpros.com
Dec 17, 2009 at 9:21 AM
