1995 Honda Accord Distributor?
143,000 MILES • 4 CYL • 2WD • MANUAL
MILEHIGH98SNAKE
Ok, I have done the basics, changed the distributor cap, wires, spark plugs, etc., but am still getting a check engine light. When I jumper the terminal, I get codes 08 and 13. The only thing I can think of to change at this point is the distributor and the coil. Any other suggestions?
Aug 27, 2008 at 2:14 PM
KHLOW2008
  • 41,812 POSTS
Hi milehigh98snake,
#08 = TDC. Could be wiring problem. Test the ohm reading of the circuit.
#13 = PA sensor. Built into ECM so you need to replace ECM to resolve.
Aug 29, 2008 at 9:17 AM
