1995 Honda Accord crankshaft timing marks
200,000 MILES • 4 CYL • FWD • AUTOMATIC
LEE1967
I need to know the timing marks for the crankshaft of a 2.2. the problem i have is only 2 cylinders are firing and i have replaced the head, and i want to make sure i have it in time.
Feb 1, 2008 at 2:45 AM
STAN OPIE
  • 6 POSTS
Timing mark on Outside dia of crank shaft pulley a notch usally lined in white when viewed from above front on engine lines up with a indicator protruding from from front of engine. Be sure # 1 clylinder is coming up on compression stroke when the marks line up, check distributor rotor to verify it is pointing to # 1 spark plug wire. The crank shaft lines with distributor firing # 1 spark plug every other rotation. The exhaust stroke the crank shaft marks will be at tdc but the distributor rotor will be 180' from #1 spark plug wire. Also cam timing could effect clylinder not firing correctly valve camshafts pulleys have timing marks also must remove timing belt covers to check timing of valve camshafts. I would not advive going this deep without an appropriate repair manual.
Jan 11, 2021 at 3:09 AM
