1995 Honda Accord cooling fans
128,000 MILES • 4 CYL • FWD • AUTOMATIC
SANDRA HUFFMAN
i was driving home today and check engine light came on. i popped the hood with the engine running and noticed that neither cooling fan was running, but that car hadn't indicated overheating. how do i check to see if i can fix myself?
Mar 11, 2009 at 3:45 AM
KHLOW2008
  • 41,812 POSTS
Hi Sandra Huffman,
When fans don't work, it would not cause the Check Engine Light to show. Get a scan done to find out what is causing the CEL.
Fans do not work until they coolant temperature rises to a predetermined value or when the AC is turned on.
Did you test if they come on with the AC?
Mar 15, 2009 at 5:24 AM
