HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Honda
Accord
Drivetrain
Transmission
Clutch
Replace/Remove
1995 Honda Accord clutch
LUVBUG42
MEMBER
1995 HONDA ACCORD
4 CYL
2WD
MANUAL
200,000 MILES
My car will go into gear and drive but it wants to rev up does my clutch need replaced and if so do I have to drop the motor
Wednesday, March 17th, 2010 AT 3:41 PM
KHLOW2008
MECHANIC
Hi luvbug42,
Yes, symptoms indicates a slippping clutch and it has to be replaced. Yu need to drop the transmission but not the engine.
While you are at it, I would recommend getting the crankshaft end seal replaced and check the clutch hydraulic system as well.
SPONSORED LINKS
Thursday, March 18th, 2010 AT 2:18 PM
Please
login
or
register
to post a reply.
Related Transmission Clutch Replace/Remove Content
1995 Honda Accord Transmission? Clutch??
Recent Services: Clutch About A Year Ago From Clutch Doctors And Cv Boot Replaced A Month Ago. Oil Changed Today. When Driving The Car...
Asked by
JasonMastr
1 ANSWER
1995
HONDA ACCORD
1995 Honda Accord
Hi I Need Your Help I Just Resently Took My Honda To The Mechanic To Have The Clutch Change And He Did But Now Everything Works Good Exept...
Asked by
geovanni
1 ANSWER
1995
HONDA ACCORD
Clutch Replacement Instructions?
This Problem Started Slowly (about A Month) - And Then We Let The Car Sit In Freezing Temperatures For Two Weeks. When Returning For Our...
Asked by
hondacar
1 ANSWER
15 IMAGES
1998
HONDA ACCORD
1997 Honda Accord Clutch Repair And Replacement
Can You Tell Me A Reasonable Price/quote To Expect For Replacement Of A Worn-out Clutch On A 1997 Honda Accord? I Have Been Quoted Ca. $...
Asked by
ICP
1 ANSWER
1997
HONDA ACCORD
Clutch Needs To Be Replaced For 3rd Time@ 113000
Replaced: Clutch Pressure Plate R&r Included Clutch Disc And Release Bearing Also Outside Labor To Resurface Flywheel, Pressure Plate...
Asked by
prawson1
1 ANSWER
2006
HONDA ACCORD
VIEW MORE
SPONSORED LINKS
Pilot Bearing Replacement
Throwout Bearing - Secondary Cylinder Replacement
Clutch Not Working
Online car repair manuals
