1995 Honda Accord Bullet kind of sound from coming from the
139,000 MILES • 4 CYL • 2WD • AUTOMATIC
MCPDEVS
Hi, I have a honda accord 4 door 1995 model. I recently started hearing a bullet kind of sound coming from the back of the car. I believe it is coming from the exhaust. Though the sound is not very high but I am not sure whether it means any serious issue? I thought I could pay some attention before it ends up in to a critical issue. If you could tell me the reason for the sound and also the fix for it, that would be great.
Thanks,
Devs
Sep 12, 2009 at 2:02 PM
KHLOW2008
  • 41,812 POSTS
Hi Devs,
That should be noise emitted by the engine misfiring.
You would need to check why the engine is misfiring. It could mean bad spark plugs, wires distriubtor cap or rotor, ignition coil, fuel injectors or fuel pressure.
Sep 13, 2009 at 6:38 AM
