The problem I am having is the brake pedal goes to the floor
15,000 MILES • 4 CYL • 2WD • AUTOMATIC
SCOTTISHBYBLOOD191
The problem I am having is the brake pedal goes to the floor and then it is like the system charges back up and there is no problem. Checked fluid and it is fine and also checked brake pads and lines all are fine. Really don't know what to do. Too many vehicle problems all at one time!!!
Jun 28, 2009 at 10:44 AM
SQM
  • 6,383 POSTS
There are few reasons why the pedal can go to the floor. One is when there is air trapped in the brake lines. Another common one is having a faulty master cylinder and it is just not able to create pressure as you press the pedal.
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Make sure there are no leaks in the brake system. Check each caliper and all the hoses.
Bleeding the brake could be a good first step.
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
If the issue exists after the brake bleeding and there are no leaks, then it is likely a bad master cylinder and needs to be replaced.
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
Oct 21, 2021 at 6:03 AM
