1995 Honda Accord blown heater hose
150,000 MILES • 4 CYL • FWD • AUTOMATIC
CHERYL1956
My heater hose blew, we replaced it. Now its sluggish in first and second, then picks up and is fine in third. When I stop the car, the top radiator hose is VERY hot, and the bottom one is cool. Did I wreck my engine? Will changing the thermostat solve the problem? It's after midnight, I gotta be to work in 8 hrs, and that's my only transportation.
Oct 20, 2009 at 7:38 PM
F4I_GUY
  • 3,302 POSTS
If you didn't overheat the engine, replacing the thermostat will do the trick.
Just make sure you properly bleed the cooling system.
Oct 22, 2009 at 1:52 PM
