The SRS light is on. I know this is for the safety restraint system (air bag)
DJBAY01
The SRS light is on. I know this is for the safety restraint system (air bag). Is there a scanner I can buy/use to scan the body control module to locate the fault code. How can I reset the light. The diagnostic connector is on the driver’s side under the panel on the right of the steering wheel. I know it is not a OBD II connection but I am not sure what type of connection it is.
Oct 11, 2010 at 1:59 PM
KHLOW2008
  • 41,812 POSTS
Hi Djbay01, The one under the driver side is the Memory Erase Signal ( MES ) connector and is for resetting the SRS light. The SCS is under the passenger side RETRIEVING DTCS Turn ignition off, connect SCS Service Connector (07PAZ-0010100) to service check connector( a paper clip would do). See Fig. 1 . Turn ignition on. SRS indicator light will come on for about 6 seconds, and then go off for 2 seconds. After 2 seconds, SRS indicator light will: "¢ Quickly flash on and off (no DTCs are set in memory), or "¢ Begin flashing DTCs
https://images.2carpros.com/forum/automotive_pictures/192750_SRSComponent95AccordFig01_1.jpg
Apr 23, 2021 at 6:22 AM
DJBAY01
I did the two wire connector on the left (drivers side) and after the two blinks the light comes on and stays on. I tried to look behide the glove compartment and didnt see a two wire connector. I saw and red connector and blue connector.
KHLOW2008
  • 41,812 POSTS
The SCS is behind the glove box near the center console. It should be plugged into a green rubber socket. Next to it would be the DLC, a 3 pin connector. DO NOT use the 3 pin connector. 2 wire connector should be grey in color.
https://images.2carpros.com/forum/automotive_pictures/192750_SCS95Accord_11.jpg
