1995 Honda Accord
JIMMY13
  • 1995 HONDA ACCORD
Engine Cooling problem
1995 Honda Accord 4 cyl Two Wheel Drive Automatic
temp goes to high when at higher rpms.
low rpms are fine even in traffic at 90 degrees
new thermo
need to run heater if highway driving
Tuesday, August 11th, 2009 AT 10:23 AM
KHLOW2008
  • 41,814 POSTS
Hi jimmy13,
The symptoms indicates cooling efficiency and since the thermostat is new, the other possibles causes are :
1. Clogged radiator.
2. Weak water pump.
3. Clogged water passages.
4. Insufficient coolant.
The most likely cause would be clogged radiator.
Sunday, August 16th, 2009 AT 3:23 PM
