1995 Honda Accord
MSMARILYN30
  • 1995 HONDA ACCORD
Electrical problem
1995 Honda Accord 6 cyl Automatic
I have a 1995 honda Accord that stalls out while driving a short distance, it will sputter when pressing the gas before dieing out, can let it sit for about an hour and will start up again and also check engine light is on.
Saturday, April 4th, 2009 AT 2:19 AM
F4I_GUY
  • 3,302 POSTS
Retrieve the code first and foremost and post it up.
In the meantime you may want to check to see if you are getting strong spark at the spark plugs, strong spark is bright and should be white/blue. If you have a fuel pressure gauge, you may also want to check fuel pressure to ensure your vehicle is getting the proper fuel pressure needed to start the vehicle.
Saturday, April 4th, 2009 AT 3:35 PM
