1995 Honda Accord check engine light
HARDYBOY29
  • 1995 HONDA ACCORD
  • 4 CYL
  • FWD
  • MANUAL
  • 140,000 MILES
Hi I have a 95 accord and it runs great but the only issue I have with the car is when the car reaches its warm up point ( not even half way up on the gauge) the check engine light comes on so if I shut the car off and then turn it back on the light goes off I wonder if it just something simple like a clogged air filter or needing a tune up can you guys help me please thanks
Monday, December 28th, 2009 AT 10:11 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Ok, you will need to pull codes. Directions below...
Connect the SCS Service Connector to the Service Check Connector. Located behind right side dash.
https://www.2carpros.com/forum/automotive_pictures/188069_95accorddtc_1.jpg
Turn key to on possition. There will be a series of flashes. First set will be Long Flashes Next Set will be Short Flashes. So, 4 long flashes would be the first number in the code or 4 then there will be short flashes lets say 3 so the last number in code would be 3. So, the complete code would be 43.
After pulling code post them here for forther diagnostics.
Monday, December 28th, 2009 AT 10:15 PM
