1994 Honda Accord Wiring Siren
150,000 MILES • 4 CYL • FWD • MANUAL
MMRUPPEL
I recently purchased a used Whelen 295HFSA1 Siren Amplifier and a compatible speaker. I downloaded the manual from the internet but I am confused on how to wire it. The only thing I want to do is hook it up to the battery and test it for functionality. I have no desire to place it in my '94 Accord. I am given 2 red wires and 2 black wires. I thought it would be simple to hook-up: red wires to positive and black to negative terminals on the battery. But, Whelen's manual spiced things up for me. Apparently I need a "fuseblock" that can support 30amps? It needs to be located within 2 ft. of the battery and connects the siren to the battery. I also need wire that's big enough to support "125% of the maximum operating current". The bottom of the unit says:
"Input Voltage 12.8VDC +/- 20%.
Input Current @ 15VDC.
@100 Watts 8 AMPS (TYP)
I don't know what most of it means and how it relates to what I need to get to run this thing.
So my question is, how do I hook up this siren to my car just to power it on for temporary use and what supplies do I need to get to accomplish my goal (fuseblock, 12 gage wire, etc.)?
If you need more information about it, let me know.
Thanks a lot!
*I donated :)
Feb 8, 2008 at 7:33 PM
2CARPRO JACK
  • 11,533 POSTS
Go to auto parts store and buy a 30 amp inline fuse (or 2 if necessary) and if you match the wire gauge to the inline fuse, you should be ok.
Feb 10, 2008 at 12:30 AM
MMRUPPEL
Thanks a lot! I bought the inline fuse and a 30amp blade fuse and it works! Thanks for the advice ;)
Feb 10, 2008 at 11:25 AM
2CARPRO JACK
  • 11,533 POSTS
Youre welcome
Feb 10, 2008 at 11:07 PM
MMRUPPEL
Is there something I can get to help me connect the cables to the battery without using electrical tape? The tape would not stick and the wires kept falling off. I know there's a bracket for the car's power supply wires that hooks around the battery terminals, but leaves no space for any other addons. So is there a bracket specifically for other appliances which need electricity that I can buy?
Feb 11, 2008 at 1:52 PM
2CARPRO JACK
  • 11,533 POSTS
Go back to the auto parts store and tell them what you want to do, they will set you up
Feb 11, 2008 at 11:05 PM
