1994 Honda Accord Windshield Wipers
EJR
Interior problem
1994 Honda Accord 4 cyl Front Wheel Drive Automatic
2 questions actually. First: My windshield wiper fluid will not squirt out when I pull the lever in order for it to. There should be some tension when the lever is pulled, however, there is not.
Second, my rear defrost no longer works. When I push the button, the light comes on as if it works, but nothing happens.
Nov 28, 2008 at 3:04 AM
KHLOW2008
  • 41,812 POSTS
Hi EJR,
Seems the wiper washer switch is faulty. There is a tiny spring loaded lever inside the switch and most probably it has broken off.
The defroster not workiing could be due to a
1. faulty defroster relay,
2. Power supply to the defroster
3. Defroster circuit malfunction, glass replacement is required.
Nov 29, 2008 at 2:25 PM
