Where is the windshield wiper motor relay switch located on a 1994 Honda Accord??
Apr 3, 2010 at 3:17 PM
RJEFFERSON422
MEMBER
Thank you for the info kng1818.
Apr 4, 2010 at 7:11 PM
CERTIFIED EXPERT
The windshield wiper relay is located under the hood fuse box between the fuse box and the cruise control actuator.
Here is a wiring diagram and the location so you can get the problem fixed.
Please let me know if you need anything else.
Best, Ken
Images (Click to enlarge)
Jan 10, 2017 at 12:50 PM
PMONEY3D
MEMBER
1 POST
1994 Honda Accord
Is there a built in "Check Home Status" within the motor that tells the system when the wipers are back in the home position? If there is, can it be located by a certain voltage level from one of the pins on the motor's terminal plug in?
