1994 Honda Accord Will 1996 v6 Speedometer cluster work on
DPITTS1979
Electrical problem
1994 Honda Accord 4 cyl Automatic 177700 miles
Will 1996 Honda accord v6 speedometer cluster work on 1994 honda accord v4? Both cars are automatics.
Jun 30, 2008 at 2:56 AM
MERLIN2021
  • 17,250 POSTS
I don't think it will, one car is pre OBDII not compatible. But check the PCM numbers, if by any stretch they are the same, then maybe!
Jun 30, 2008 at 3:11 AM
KHLOW2008
  • 41,812 POSTS
Hi dpitts1979,
Working should not be a problem if it fits, but you need to check if the rpm rate of the speedometer motor is the same, if not you would not get the correct speed reading.
Jun 30, 2008 at 3:16 AM
