1994 Honda Accord Unable to shift gear when car is started
267 MILES • 4 CYL • 4WD • MANUAL
EVAN5489
My 1994 Honda Accord will not shift into gear when it is started, however, it is able to shift when the engine is off.
Dec 27, 2009 at 9:02 AM
  • 31,937 POSTS
Hi there,
You more than likely have a leak in the clutch hydraulic system, you will have to see if it is the master or slave cylinder and replace which ever is faulty, then re bleed the system of air.
Mark (mhpautos)
Dec 27, 2009 at 2:55 PM
