1994 Honda Accord tube seals
BADAM2290
Engine Mechanical problem
1994 Honda Accord 4 cyl Two Wheel Drive Automatic
how do you change the tube seal, i changed the valve cover gasket and the top 4 circle gaskets, but how do i change the thin o ring looking gaskets?
Aug 15, 2010 at 7:23 PM
MMPRINCE4000
  • 8,548 POSTS
You have to remove valve cover, punch out tube seals from top, install from inside. Use socket about same size as seal.
Aug 16, 2010 at 2:01 AM
