1994 Honda Accord The Fan Makes A Strange Noise?
110,000 MILES • 4 CYL • 4WD • AUTOMATIC
AMMAGO
I have 1994 honda accord and the car is in good condition but when i put on gas it makes a strange noise and also when i turn off the car it makes the same noise after couple of minutes. Then, i found out that the noise was coming from the fan by the radiator. So, if you kind enough to tell me what the problem is? Thank you kindly.
May 31, 2008 at 4:25 AM
KHLOW2008
  • 41,812 POSTS
Hi ammago,
The bushes of the fan motor armature are worn and you need to replace the motor soon before the motor gives way.
There are 2 fans, check and see which is the source.
May 31, 2008 at 7:00 AM
