1994 Honda Accord starter
205,300 MILES • 4 CYL • FWD • MANUAL
PASPUNXRA
My 94 Honda Accord EX will start intermittently. Usually involves trying to crank it several times before it actually kicks over and starts. To my knowledge it could either be the starter itself or the ignition switch. I am trying to remove the starter so that I can have it tested and I cannot find all the bolts that hold it in place. I have found two of them and they are removed, but the starter is still firmly in place and will not budge. I was wondering if there was a trick to remove the starter if there are only two bolts that hold it in place, or if there is a third bolt that I cannot find. Any pictures or information would be helpful at this point. I am extremely frustrated because this is the only real problem I have ever had with my vehicle.
Jan 25, 2008 at 7:57 AM
MASTERTECHTIM
  • 4,750 POSTS
look to see if there is a bolt going the opposite direction
Jan 25, 2008 at 8:01 AM
