1994 Honda Accord speedameter/temperture gage/gas gage
18,000 MILES • 4 CYL • 2WD • MANUAL
PALUNGA
Speedameter drops on and off when it feels like it.The temperture gage needle not working at all.Gas gage gets stuck. I checked the fuel unit and it looked ok. Could someone tell me if this caused by sesor units or were the problem may be.
Jun 8, 2008 at 8:08 AM
KHLOW2008
  • 41,812 POSTS
Hi palunga,
The speedometer is most probably due to a faulty speed sensor at the trans. The D4 should be blinking when that happens.
Temp gauge not working might be due to a disconnected or faulty temp sending unit.
Gas gauge stuck at what position? If at full, then it is a ground problem, either the gauge or its wiring nearby meter cluster.
Jun 9, 2008 at 12:42 AM
