1994 Honda Accord my motor is missing
DMNELSON40
  • 1994 HONDA ACCORD
  • 4 CYL
  • FWD
  • 209,000 MILES
My gas gauge stopped working and the car ran out of gas. So I changed the fuel filter plugs wires than tested the wires replaced the feul pump and the strainer. Then I flushed the fuel lines and cleaned the fuel rail and replaced the injecters and the motor is still missingand I would want to know what else would cause the motor to miss the autozone said that the o2 sensor would cause it to miss but the engine codes are saying the o2 sensor is fine and it isnt tripping any more warning light or engine codes.
Thursday, June 17th, 2010 AT 8:09 AM
  • 31,937 POSTS
You may have a faulty injector get a fuel rail pressure test done this can show up a leaking or faulty injector.
Mark (mhpautos)
Thursday, June 17th, 2010 AT 8:28 AM
DMNELSON40
Well I did that before and after the fuel pump was replaced it was low before so I replaced it with a new one and it was where it needed to be with fuel pressure
Thursday, June 17th, 2010 AT 3:10 PM
  • 31,937 POSTS
Have you done a compression test?
Mark.
Thursday, June 17th, 2010 AT 4:39 PM
DMNELSON40
No is that have some thing to do with the exaust system. I talked to a friend and he said that the o2 sensor would cause it to miss is there a way I can check on it because the warning for a bad o2 sensor is d4 code 1 and I checked it and it wasnt putting out no code
Thursday, June 17th, 2010 AT 10:28 PM
  • 31,937 POSTS
An O2 sensor if faulty will normally case the ECU to run rich, normally it will not cause a misfire, I would get the compressions check as a precaution.
Mark (mhpautos)
Friday, June 18th, 2010 AT 3:08 AM
