I am trying to replace the rotors on my Accord wagon
194,000 MILES • 4 CYL • 2WD • AUTOMATIC
KRUPER21
I am trying to replace the rotors on my Accord wagon. The rotor is behind the hub assembly. I have tried using a slide hammer with no success. I did remove the bolts in the back before using the slide hammer. Are there any other tools someone could recommend to get this apart so I can get my rotors changed? Thanks.
Oct 2, 2008 at 5:30 AM
SQM
  • 6,383 POSTS
Replacing the rotor on these years / body accords will require you to first remove the knuckle with the rotor mounted on it.
Then remove the rotor.
It is little more time consuming than a typical front wheel drive rotor change.
I have attached the replacement instructions below.
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
Oct 21, 2021 at 12:00 AM
