caliper piston turn in to collapse back inside, or does it go back with pressure
1994 HONDA ACCORD
180,500 MILES • 4 CYL • FWD • MANUAL
SGTMAJOR
  • 17 POSTS
Does this particular caliper piston turn in to collapse back inside,or does it go back with pressure,like the front calipers and if it turns to reset,do you need a special tool like a spanner wrench?
Thanks
Aug 9, 2008 at 6:33 AM
2CARPRO JACK
  • 11,533 POSTS
Yes, it must be turned to retract.There are special tools to do this, but sometimes you can use needle nose pliers in the slots on the piston and push in as you turn clockwise.There are small pins on theinboard pads, be surethey line up with the slot on the piston,this alignment is what makes it all work (e-brake). You only need to retract the piston enough to get the caliper to set down over the pads, doesnt have to be all the way in
Apr 9, 2021 at 11:40 AM
SGTMAJOR
  • 17 POSTS
The left side retracted using a small flathead screwdriver,but I noticed the outer pad looked like a old shoe heel only worn at one side.Does this mean the rotor is "out of round"?The right side didn't retract at all,should I open the bleeder screw valve?
Thanks
KHLOW2008
  • 41,814 POSTS
Hi sgtmajor,
No, it means the slider bolts are stiff and requires to be lubricated.
If the left piston can be turned, you need to apply a little pressure to push it back while turning. Check if the handbrake cable has enough freeplay.
2CARPRO JACK
  • 11,533 POSTS
Sometiems they wont retract without the proper tool to apply enough torque to turn it. Opening the bleeder may help, but not likely.See if local auto parts store has a tool rental program or even an inexpensive version of what you need, If you are going to have the car for a while it may be a good investment. Also as mentioned previously, be sure the caliper slides move freely and are lubed
Apr 9, 2021 at 11:41 AM
